- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
SXK30 Orbi Pro WiFi 6 Mini System: Business Mesh WiFi System for WFH
- Mark as New
- Bookmark
- Subscribe
- Permalink
Work-from-Home Security and Performance
In an era where business professionals and students are working and learning from home, network congestion and security are real issues. The Orbi Pro WiFi 6 Mini Mesh system provides the capability to maintain secure and separate WiFi channels. Featuring the latest WiFi data security protocol, WPA3, along with support for up to 4 separate SSIDs and VLANs, the Orbi Pro WiFi 6 Mini Mesh System enables network streams to be securely separated from each other, for example by creating a work-from-home network stream, a learn-from-home network stream, an entertainment network stream, and a guest/customer network stream.
The NETGEAR Business Orbi Pro WiFi 6 Mini SXK30 2-unit kit and 3-unit SXK30B3 WiFi system are both available in North America now. Get great WiFi for work from home and more. Let us know what you think of this new offering in the thread below.
Orbi Pro WiFi 6 Mini By the Numbers:
WiFi 6 Speed per Unit: AX1800 (1.8Gbs)
Radio Configuration: 2×2 Dual-band
Ethernet Ports per Unit: 4-Port Gigabit Plus featured Switch with VLAN control
Max Users: 256
Max Concurrent Connections: 40
Coverage Per Unit: 2000 sqft
Wireless Security: WPA / WPA2 / WPA3
Local Management GUI: Yes – Preferred Method
Insight Remote Management: Yes – Optional
Read the Orbi Pro WiFi 6 Mini Press Release.
Visit the Mesh WiFi for Work from Home blog.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: SXK30 Orbi Pro WiFi 6 Mini System: Business Mesh WiFi System for WFH
Nice, we will buy just need to know if it will work with the SXK80?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sounds like you already have the base (router). If so, you only need more SXS80 units. Those are the sat units. I have not seen 2-packs or 3-packs of those. If you already own the SXK80 base router, pricing is such that it would make little sense to buy a new kit.
Beware Orbi-Pro WiFi 6 SXK80 is not compatible with netgear’s Orbi WiFi-6 for residential (RBK852) nor Netgear’s earlier WiFi Pro models.
- Mark as New
- Bookmark
- Subscribe
- Permalink
"These kits have a base (router) plus 1 satellite (sat) or base (router) plus 2 sats."
I needed to know if it will work with the SXS80 as I know I can just buy the 1 satellite on amazon. :]
Yes. I have the one SXS80 and one SXR80.
Thanks for the info!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Betreff: SXK30 Orbi Pro WiFi 6 Mini System: Business Mesh WiFi System for WFH
good
- Mark as New
- Bookmark
- Subscribe
- Permalink
Wifi
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sounds like you as of now have the base (switch). Assuming this is the case, you just need more SXS80 units. Those are the sat units. I have not seen 2-packs or 3-packs of those. In the event that you effectively own the SXK80 base switch, evaluating is to such an extent that it would look bad to purchase another pack
- Mark as New
- Bookmark
- Subscribe
- Permalink
The SXR30 and SXS30 do not support and will not pair with Orbi Pro WiFi 6 router (SXK80) or satellite (SXS80).
DaneA
NETGEAR Community Team
