Orbi WiFi 7 RBE973
Reply
SXK80 - What tools are available to rewrite(restore) the device's firmware
shejialun
One of the purposes is to restore the firmware (just like using itunes to restore ios) and the other purpose is to try to rewrite the firmware first in case of device failure
I have gotten the NMRP tool to rewrite the firmware before when using the R7000 device, but I was told by Netgear tech support that this tool is not available on the SXK80, even though I did a test and the result is that I can only rewrite the firmware successfully using the NMRP tool when connected to port 5 of the device.
So what is the available tool to rewrite(restore) firmware on SXK80 device? thanks.
Message 1 of 5
BruceGuo
NETGEAR Expert
Re: SXK80 - What tools are available to rewrite(restore) the device's firmware
I do not recommend NMRP. Please follow this page to try to restore firmware via tftp if somehow your device is bricked.
Message 2 of 5
shejialun
Hello @BruceGuo ,
Could you provide a guide or link to use TFTP?
Because I've only used the NMRP tool so far, thanks.
Message 3 of 5
BruceGuo
NETGEAR Expert
Message 4 of 5
shejialun
Hello @BruceGuo
Why do you recommend using the TFTP client more than the NMRP tool?
In fact the NMRP tool is simpler to operate and the NMRP tool uses TFTP as well, thanks.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 756 views
  • 0 kudos
  • 2 in conversation
Announcements
