Orbi WiFi 7 RBE973
Reply
SXR80- Guest Wifi - Access to Printer in Main Wifi
jcharnet
Guide
Hello everyone,
I have my main wifi configured in wireless1, and I also have the guest wifi set up. Is it possible to allow guest to access a specific device on the main wifi? For example a printer? I'd like to give guests the ability to print, is there any "magic" routing that we can do to make that happen?
Thanks a lot,
Joao.
Message 1 of 4
schumaku
Guru
Re: SXR80- Guest Wifi - Access to Printer in Main Wifi
Just for one device ... probably not, to my knowledge, Netgear does still not want to understand why we asked for allow adding granular firewall rules a looong time ago already. The convenience approach would be to enable mDNS allow spanning over multiple VLANs - inheriting more risks than typically intended, see for example here
Message 2 of 4
BrianL
NETGEAR Moderator
Hi @jcharnet,
You can also check the product SW manual for more information about mDNS and make sure your ORBI network is up to date.
Kind regards,
Message 3 of 4
BrianL
NETGEAR Moderator
Hi @jcharnet,,
Were you able to check and setup mDNS in your ORBI router to make your printer available in your other VLAN?
Kind regards,
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 522 views
  • 0 kudos
  • 3 in conversation
Announcements
