Reply
SXR80 WIFI sheduling
Raul34
T
Hi all
For WIFI sheduling it would be great if there is an option to insert more than one timeframe/day.
The actual issue is, that it is not possible to generate a shedule like:
WIFI on from 06:30am to 01:00am
Only 06:30 to 00:00am works. but if you need the WIFI until 01:00am, thats not possible with this design of shedule.
Can you please update/correct this.
If I`m doing somthing wrong, I would be open for advices/guidance.
Thanks
Message 1 of 4
schumaku
Guru
Re: SXR80 WIFI sheduling
Design or implementation limitation.
Message 2 of 4
BruceGuo
NETGEAR Expert
Just an update - we are working on if providing 2 segments in 1 bar to have better configuration in wifi scheduling.
Message 3 of 4
Raul34
Great, this is exactly what we are looking for.
Thanks for your replay.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 762 views
  • 1 kudo
  • 3 in conversation
Announcements
