Orbi WiFi 7 RBE973
Reply
SXS50 firmware update problem
limesin
Hi
I have updated  SXR50 router first, before SXS50 satellite.
I have no idea how to update the satellite now, because there is no check box in router GUI to do that.
Every suggestion very welcome
Thx in advance.
Message 1 of 3
Accepted Solutions
BruceGuo
NETGEAR Expert
Re: SXS50 firmware update problem
Does SXS50 connect to SXR50 wirelessly? Or no, can you try wire SXS50 and SXR50 so you will see SXS50 is under SXR50 management.
Message 2 of 3
All Replies
BruceGuo
NETGEAR Expert
Message 2 of 3
limesin
Hi
Thx for your reply.
I'm just finishing the process of restore factory settings, and I can see under SXR50 the SXS50.
I will try to update and then I will finish this post.
WORKED!
Both items has been updated.
Anyway thanks for your help!
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1144 views
  • 0 kudos
  • 2 in conversation
Announcements
