Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Reply
Satellite does not sync the SSIDs of synchronized router (SRR60)
oakway4
Follower
I have configured two WLANs with certain SSIDs and satellite and router both tell to be well synchronized.
The satellite still provides the ORBI68 SSIDs and nothing else.
Message 1 of 2
JeraldM
NETGEAR Employee Retired
Re: Satellite does not sync the SSIDs of synchronized router (SRR60)
Welcome to the community!
How did you setup the router and satellite? Did you use the NETGEAR Insight App or set it up manually via Web Browser Setup indicated here?
Also, please try performing a Reset on the satellite only by holding the Reset button for at least 7 seconds if not yet done, then resync the satellite to the router.
Lastly, please check if both router and satellite are upgraded to the latest firmware, please check here on how to upgrade the firmware. (The latest firmware for both router and satellite is v2.6.2.202)
JeraldM
NETGEAR Community Team
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 465 views
  • 0 kudos
  • 2 in conversation
Announcements
