Orbi WiFi 7 RBE973
Reply
Single Windows DHCP for all VLANs
Nakatomi2010
Follower
I have a home network to which I have a five node Hyper-V cluster.  I'm upgrading from the Orbi RBR50 to the SXK80.  I use a Windows based DHCP server currently and was hoping to continue to do so after the replacement.
In looking over the settings on the SXK80 it doesn't look like I can tell
Message 1 of 2
JeraldM
NETGEAR Employee Retired
Re: Single Windows DHCP for all VLANs
@Nakatomi2010,
Welcome to the community!
You can try setting the SXK80 to AP mode if you plan to keep your Windows based DHCP server.
You may refer to page 174 of the user manual here for the steps.
JeraldM
NETGEAR Community Team
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 476 views
  • 0 kudos
  • 2 in conversation
Announcements
