Reply
Suggestion for how many Orbi Pro I should buy?
bmgarcia
Tutor
I am looking to set up wifi for an indoor eatery that is 2 stories with multiple food vendors selling various foods. The space is around 6,000 square feet. How many Orbi should I buy?
Message 1 of 2
NaderA
NETGEAR Expert
Re: Suggestion for how many Orbi Pro I should buy?
Do you want it all to be the same network or different networks for each vendor?
If the same network is what you want, then you need to purchase a kit (Router + Satellite) and additional satellite(s) to cover your space. depending on the configuration of the space and the walls, you may need 1 or maybe two satellites.
If you want a network for each vendor, then you have to purchase a kit for each of them.
Model: Orbi Pro Tri-band WiFi System (SRK60) AC3000
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 983 views
  • 1 kudo
  • 2 in conversation
Announcements
