Orbi WiFi 7 RBE973
Reply
Using RBR50 Router or Satellite SRK80
4Papa
I know the two systems are incompatible wirelessly, but can I use the RBR50 Router or one or more of the Satellites with the SRK80 (Orbi-Pro 6) system as an Access Point if I wire it from the router?  The SRK50 system (which I loved) is not even three years old.  Seems such a waste to not be able to use it in some fashion with the new business-oriented SRK80.  Thanks..
Message 1 of 4
schumaku
Guru
Re: Using RBR50 Router or Satellite SRK80
All you can do is to configure the RBx50 in wireless access point mode.
Message 2 of 4
4Papa
Thanks for the reply.  Would that be just the RBR50 router and not the RBS satellites that will work as an AP., and that the connection between the RBR50 router and the SX80 router is wired?  Again, thanks.
Message 3 of 4
schumaku
Guru
The RBR/RBS system can work as access point with just the "router" acting as the basestation for the wireless satellites.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 974 views
  • 0 kudos
  • 2 in conversation
Announcements
