Reply
What is FastLane3? Orbi Pro SRK60
xmnjx23
Follower
What is Fastlane3 and how does it relate to Orbi Pro?
Message 1 of 3
Jedi_Exile
NETGEAR Moderator
Re: What is FastLane3? Orbi Pro SRK60
Fastlane3 refers to dedicated backhaul via the 3rd radio on the system.   Orbi Pro has dedicated backhaul radio between Router and satellite units in order to provide reliable and fast communication between different nodes.
"Although darkness may surround you, if you seek it, there will always be a glimmer of hope shining strong."
Message 2 of 3
NaderA
NETGEAR Expert
It is a dedicated 4x4 on the 5GHz band to backhaul data between the router and the satellite. This radio is not used for normal WiFi service and as such, there will not be any competition for resources or bandwidth.
Model: Orbi Pro Tri-band WiFi System (SRK60) AC3000
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1869 views
  • 0 kudos
  • 3 in conversation
Announcements
