- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Wired Backhaul issues with SXR30
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have 2 satellites, 1 wireless and attempting to set up the 2nd for wired backhaul, which I thought I had done and working (appeared to work for about 6 months) now it connects and drops and connects and drops.
I've updated the firmware on everything, I've reset the satellite, re-synced it. and after resyncing it will work for about a day and then goes wonkie.
By wonkie it will connect (blue light) and then it will drop (magenta?? light) and then go back to blue.. and work for a few min.. then drop.
The satellite is plugged in to the back of the orbi router in the 1st plug.. Just not finding very much info to help with this issue.
Firmware: v4.3.2.102,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Wired Backhaul issues with SXR30
What CAT# lan cable are you using between the SXR and SXS? CAT6 is recommended.
Does the other SXS do same thing in this configuration?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any progress on this?
