Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Reply
how to extend SXR80 (Cost effective)
ALWAYSaSTUDENT
Follower
I have SXR80 router and 1 satellite. Router at Level 1 and Satellite at Level 2. Now like to enhance week signals at Level 3. Adding a satellite is quick, easy and expensive option. No need of high throughput at Level 3. Would appreciate some cost effective options.
Message 1 of 2
Guru
Re: how to extend SXR80 (Cost effective)
You can always use just a simple wifi extender. It won't integrate with the network for the orbi usage but does work.
I've seen a EX2700/3700 (and other higher performance devices) connected to an orbi network just for lower throughput coverage.
Again, its not going to integrate or have the same (or even close) performance but it should connect
Current setup: CM2000-> RBE973S-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/100mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 502 views
  • 0 kudos
  • 2 in conversation
Announcements
