Orbi WiFi 7 RBE973
Reply
orbi pro router srs 60
athverson
Follower
Wifi hasn't worked in over a day. I have an orbi pro router srs60 and satellite. Last night the router and satellite were displaying a pink/purple light, and my wifi was saying connected without internet.
I looked up every solution, and eventually ended up factory resetting the router. I tried logging in the orbi app to finish setting the router up after resetting it, but the wifi is still saying connected without internet. The light on the router and satellite and white now and not pink/purple
What do I do
Message 1 of 2
Guru
Re: orbi pro router srs 60
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What do I do
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 387 views
  • 0 kudos
  • 2 in conversation
Announcements
