Orbi WiFi 7 RBE973
Reply
srs60 wire connection
mtc_8
Follower
can i mix and match connections? between satelittes router and switch?
i am adding a satellite to my system setup, i got a router srs60 connected directly by with wire to a satellite, and from the srr60 router i got a swtich connected to a free port. my question now from the switch can i connect a satellite? due to the location i like to see if possible to do this
appreciate
thanks.
Model: SRK60B03|Orbi Pro Tri-Band Business WiFi System
Message 1 of 2
Guru
Re: srs60 wire connection
yes you can connect a satellite to the switch. Whenever I use satellites, I'm connecting through a switch.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 462 views
  • 2 kudos
  • 2 in conversation
Announcements
