Orbi WiFi 7 RBE973
Reply
RBS40V and 2.4Ghz
whenasked
RBS40V and 2.4Ghz
I have a RBR50, RBS50 on Router Firmware Version V2.7.2.104.
I also have RBS40V on  Firmware Version: V2.6.2.4_1.0.1.
When devices connect to 2.4Ghz on RBS40V, devices stop working. When I switch off RBS40V, and when those devices connect to router or to the other satellite, those 2.4Ghz devices start working again.
Thanks
Model: RBS40V|Orbi Voice Add-on WiFi Satellite and Smart Speaker
Message 1 of 9
Guru
Re: RBS40V and 2.4Ghz
do you have the voice running in extender mode or orbi mode?
also, have you tried a simple factory reset and reinstall of the voice?
Message 2 of 9
whenasked
In orbi mode. Tried several resets..same result
Message 3 of 9
Guru
If you log into the rbs40V using its ip address, what does it show for its status page?
Message 4 of 9
whenasked
It shows connected.
Message 5 of 9
Guru
Photos have to be approved by a moderator. it can take a while. Or you can click on "choose file" and attach them that route.
Message 6 of 9
whenasked
Message 7 of 9
Guru
Do you happen to have your guest network running?
If you disable it, what happens?
Message 8 of 9
whenasked
I have not tried that. I wanted all cameras and IoT devices on my guest network rather than on my main network.  Thanks
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 1629 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
