- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ADD CAN YOU ADD RBS50 SATELLITE TO RBK752
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am looking at the Orbi AX4200 (RBK752) and was wondering if required in the future could I add an additional RBS50 satellite? Also what would the performance implication be as the RBS50 is wifi5?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ADD CAN YOU ADD RBS50 SATELLITE TO RBK752
You can add a RBS50 to a RBK852 but only wired backhaul, it won't connect using wifi and it will only use a AC connection no AX. They were supposed to add the ability to wifi backhaul together but I don't think it's been implemented yet. I'd think the RBK752 would work the same way.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am also getting the RBK753 today, and currently have an RBR50, RBS50, and W30 Wallunit.
I was hoping to setup my 3 AX4200 throuhgout the house and use one of the RBS50 or W30 either in the garage or another location.
Would i only be able to connect the RBS50, by physically connecting it to a live ethernet port in the house? I have an extra port that i can do this, but not necessairly in the most convenient location.
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, RBS50s can be ethernet connected only to the Orbi AX system. Wireless is still not compatible at this time.
@Jonnybunker wrote:I am also getting the RBK753 today, and currently have an RBR50, RBS50, and W30 Wallunit.
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the quick reply -
So i would want to keep the RBS50 to setup the Wired Backhaul, and then in hope that in a new firmware or update at somepoint, they may make the Wireless connectivity compatible between the AX and AC units at a later date, and if they did i could better place my system.
And the W30 unit, would be rendered useless until they do allow for wireless connectivity between the AX and AC units -
Okay, I think I will sell the RBR50 and the W30, appreciate the help and let me incorrect in any of my thinking.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would keep the RBR50 for back up in case something happens or keep it and test the Orbi AX system out first before letting the RBR50 go.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Okay thanks again, and I couldnt remmeber, does the RBR50 have the ability to be setup as a satellite , or does it only work as a main Router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
RBRs only work in router or AP mode. Can't operate like RBS.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I use two RBS50s with my RBR850 and RBS850. The RBS850 is wireless backhaul and the two RBS-50s are wired.
Only thing to think about is that the RBR850 will not manage the firmware properly in the RBS50's -- so you will have to manually check, download and install any available firmware upgrades (currently at V.16)
Obviously the RBS50s will not have AX capability... but otherwise work just fine.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the RBK753 with 1 on each floor right now but was considering using my RBS50 in one spot where I could backhaul and gain some coverage. Would the entire MESH no longer be able to use AX connection or only specific devices that ended up connecting to the RBS50. Sorry if that is a dumb questions and I appreciate your help
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just the devices connected to the non-AX satellites lose AX capability. All other portions of the mesh will be fine.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
