- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
AX4200 vs AC3000
- Mark as New
- Bookmark
- Subscribe
- Permalink
AX4200 vs AC3000
I just ordered an AX4200. I've been using an AC3000 for a few years. I recently upgraded to ATT fiber and expect I will see an overall improvement in WIFI speed with the AX4200 (ATT fiber is up to 1 gig). Any other improvements I should gain by moving to the AX4200 from the AC3000 or did I make a bad upgrade purchase?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: AX4200 vs AC3000
Well you get AX mode over AX. Back haul speeds are 2400Mbps vs 1733Mbps.
Theres no USB ports on Orbi AX systems.
Might compare the spec sheets between the two.
Please post about this over in the ORbi AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Good Luck.
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Modem Mode | Wifi Router MK83+ and RBK963 | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50v2, XR450/500/700, EX7500/EX7700
- Mark as New
- Bookmark
- Subscribe
- Permalink
Okay....I'm new to the site. I'll post over in the AX section.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
in my experience, you are not going to see a significant performance boost with the AX system. It won't really make any difference for your AC clients, unless the AC signal you're getting is on the weak side as the AX will provide a stronger signal. My AX clients get a slightly faster connection, around 50 Mbps more, than my AC clients do, so not a great deal of difference unless I take them very near the router where they'll get 700-800 Mbps speeds.
I'm not saying it's not worth the upgrade, but in my real world usage it's not significantly different. YMMV.
- Mark as New
- Bookmark
- Subscribe
- Permalink
In my experience, replacing the Orbi AC3000 with the Orbi AX6000 actually improved IOT 2.4GHZ devices connection strength and speed. Nothing dramatic for speed but helped the stability of connected cameras and the speed they respond when viewing cameras. This may be more related to revised antenna design vs AX speed however. However, the AX4200 has two less antennas than the AX6000 so that should be considered.
- Mark as New
- Bookmark
- Subscribe
- Permalink
My Orbi AC3000 worked much better. I tried to set this up for WIFI only and the whole thing crashed. It took my a couple of hours just to get it working. Called Netgear and was #19 in line.
Has anyone had luck with returning products purchased through Netgears online store?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Something definitely wrong there. I set up my RBK752 yesterday in ten minutes and it's running with no issues.
Netgear support hasn't been stellar in the past, so I can feel for you. I've returned equipment to Netgear before it was pretty easy but I do think I did have to pay return shipping to them.
