Orbi WiFi 7 RBE973
Reply
About 2/3 weeks ago began having issues where the Orbi
gamenlegend
Guide
Can I get access to the beta as well.  About 2/3 weeks ago began having issues where the Orbi would lose internet connection from my xfinity modem.  I tried restarting the modem and doing a manually upgrade to 4.6.8.5.  When the issue happens, some 10-15 times a day, usually I get a DNS issue on the webpage.
When connected directly to my modem (a few other devices) this doesn't occur.  It strictly seems to happen to devices attached to the orbi system.  Some help would be greatly appreciated.
Message 1 of 9
Guru
Re: About 2/3 weeks ago began having issues where the Orbi
There is no beta FW currently available.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Is IPv6 enabled on the RBR?
Do you have email logging enabled? https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/Enable-Email-Logging-and-Router-Rebo...
Message 2 of 9
gamenlegend
Guide
Provider: Xfinity
model#CGM4331COM
Always in bridge mode.
No issue with internet dropping when connecting devices straight to modem via ethernet. Devices connected to orbi router via ethernet lose internet as well.
Yes
The outlined restart process has been done multiple times.
Yes
3600 Sq ft
What is the distance between the router and satellite(s)?
About 70 ft to downstairs unit. Second satellite has an ethernet backhaul.
No. This is something I always disable.
Enabled it after your initial post.
Message 3 of 9
Guru
What mode is your ISP modem working in? Router or Modem only?
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try #2 first...
Message 4 of 9
gamenlegend
Guide
I was editing my reply...
Modem is in modem only mode. Router has been switched to bridge since I recieved it. I always use my own routers so this has always been the setting.
No issue or concern for double NAT
Wireless radios are also always disabled.
Message 5 of 9
Guru
Does the front LED turn PINK on the RBR at all?
3600 Sq ft
Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
Try enabling it and see if it helps with DNS issues.
Lets see if this changes anything...
Message 6 of 9
gamenlegend
Guide
Why would enabling email reports/logging make a difference? The issue is still occurring.
Message 7 of 9
Guru
We are tracking a problem in FW where there is a mysterious reboot of the RBR causing a disconnect with ISP modem or services. Others including me have enabled email logging which seems to stop these reboots from happening:
Message 8 of 9
gamenlegend
Guide
Good to know. I'll drop the rate down to every hour and see if it makes any positive changes.
Thank you
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 991 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
