Orbi WiFi 7 RBE973
Reply
Access Denied Help Please
Nobber1066
Hello I have Orbi RBE960 and two satellites updated to
Firmware Version
V7.2.6.21_5.0.20
tonight I have started to get access denied on some websites example
Access Denied
You don't have permission to access "http://www.johnlewis.com/our-shops/leicester/?" on this server.
Reference #18.8a3e1202.1694463553.3cef1ea3
I dont have access control on and no sites\services are blocked
Can someone advise how to resolve please
Thanks
Message 1 of 4
Accepted Solutions
Guru
Re: Access Denied Help Please
Is this happening across all devices?
Do you have Armor or Smart Parental Controls enabled with in the Orbi mobile app at all?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Message 2 of 4
All Replies
Guru
Message 2 of 4
Nobber1066
Thank for the quick reply,
I am using a BT Smart Hub 2 in bridged mode, everything was working ok since the Firmware update
BUT I did not reboot the Smart Hub, which I have just done and now all appears to be ok
Thank you for pointing me in the right direction 😉
Message 3 of 4
Guru
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 3056 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
