Orbi WiFi 7 RBE973
Reply
Add to RBK7535??
dmoe0826
Follower
Add to RBK7535??
I currenlty have an RBR50 with 1 satelite. I was thinking of upgrading to the RBK7535 package from Costco (router +2 sat) for better coverage. Is there any chance I'd be able to connect, at the least, the RBS50 to the new system? Or would it all be garbage after upgrading? Should I just add an additional satelite to my current set-up? Thanks!
Message 1 of 2
Guru
Re: Add to RBK7535??
RBS50s are not wirelessly compatible with Orbi AX systems. They can be connected via ethernet though:
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-Sy...
Netgear has set up a community forum specifically for the Orbi AX product. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum.
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 431 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
