Odompointe's avatar
Odompointe
Follower
Jun 18, 2022
Ax6000 outdoor compatible satelite
Trying to find an outdoor satellite/extender to go with my new AX6000 mesh system....any recommendations?  The only one I saw said that it was not compatible with the 6 system.
1 Reply
  • Odompointe
    The only outdoor rated satellite Netgear has is the RBS50Y.
    While it will not connect to the AX6000 as a satellite - the RBS50Y does have an "Extender" mode and will provide the connectivity to your AX6000.
    I am not sure how available they are though.
