Orbi WiFi 7 RBE973
Reply
Bad connection to Orbi RBS850 satellite
UrbanL
Guide
Hello I bought an Orbit RBK853 (with RBR850 and RBS850) before Christmas 2019. I'm about to throw the device out and buy another product, because I have several problems so far and still no solution.
a) the Netgear support is an endless loop I tried 3 times over 40 min at different times and now I have given up. I am already quite annoyed about the manufacturer and product.
b) I have a signal strength of -50 dBm when measuring the network quality, which I find very low when I am about 2m away from the device. Is this normal?
c) in addition (same distance approx. 2m) the signal breaks off from time to time while gaming. It's not my network provider's fault, because my computer, which is connected via LAN cable, can surf perfectly.
The only thing stopping me from throwing the device out is the price and the effort for new installation. Possibly the device is also simply defective - I speak parallel with my handler.
With the problems I have (quality) I can't recommend this part. Also here with AX Forum you can not select the product.
Some technical information: Firmware V3.2.10.11, 5GHz, Channel 8 or if you need more info please contact me.
best regards Urban
Message 1 of 6
Accepted Solutions
Guru
Re: Bad connection to Orbi RBS850 satellite
Any older CAT5 cabling, I would upgrade for sure. CAT6 is mimimum now days.
Glad the system is working now. Please mark your thread as solved so others will know.
Enjoy. Smiley Wink
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RAXE500 and RBKE963; Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 6 of 6
All Replies
Guru
What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
Is the Orbi system operating in Router or AP mode?
IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Be sure that CTS and RTS values are changed to 2347 under Advanced Tab/Advanced Settings/Wireless Settings
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://www.youtube.com/watch?v=ePZSc7vnRlQ
Try sending a forum Moderator a PM if you want NG support help.
@Blanca_O
@ErnestTheGreat
Ask about an RMA if one is needed...
Message 2 of 6
UrbanL
Guide
Thanks for your fast reply - I try to anwser them
1. What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
UL: the Manufaktur is arcadyan model vrv9519 labled by my telco provider swisscom
2. Is the Orbi system operating in Router or AP mode?
UL: no it is router mode - and I connected it to my router from my telefon company -> might this be a / the problem?
3. What is the size of your home? Sq Ft?
UL: about 3000 SqFt (=280sqm - but I'm not using it for all sofar).
4. What is the distance between the router and satellite(s)?
UL: 30 ft = 10meter
5. What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on
UL: not sure - just found in Orbi-Mob-App 8 and 48
6. 2.4Ghz and any unused channel on 5Ghz.
UL: ??
7. Any Wifi Neighbors near by? If so, how many?
UL: yes but actually quit far away. I usually see about 4-6 other wifis
8. IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes.
UL: IPv6 is currently disabled - should I turn it on?
best regards
Urban
Message 3 of 6
Guru
It maybe possible that this model has a built in router and wifi already...if so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try setting manual channel to 1, 6, 11 or 13. Use a web browser to log into the RBRs web page to change channels, you can't change channels using the Orbi app.
Message 4 of 6
UrbanL
Guide
thank you for the answer. I have now had the time to reinstall everything again. So far it looks like I have no more connection problems. But every now and then the network is still very weak 3Mbps instead of 500Mbps. I will now renew all my old Ethernt cables to Kat7 and hope to have a really good network 🙂 Thanks again!
Message 5 of 6
Guru
Enjoy. Smiley Wink
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 2041 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
