Orbi WiFi 7 RBE973
Reply
Can I use AX4200 to tell me if kids have logged in online with their chromebooks?
atomarchio
Tutor
I just bought the Orbi AX4200 wifi router system.   Can the Orbi app tell me if my kids have logged into their chromebooks online just before school?
I see the device list but not exactly how this work with the chromebooks since they are turned off when school ends and then turned back on every morning and reconnected to wifi.  Can I see an exact time when the logon to the wifi?
Please help.  Thanks/
Message 1 of 4
Mstrbig
Master
Re: Can I use AX4200 to tell me if kids have logged in online with their chromebooks?
The Orbi app and GUI has settings to do what you ask. I'm not sure shuuting down would keep the info, as Orbi, unlike Veop, does not visibly retain disconnected devices.
Did you read the manual to see if it covers it?
Orbi RBK53 System/RBR50/RBS50/RBS50. + Orbi Voice RBS40V
RBK753 system/RBR750/RBS750/RBS750 + RBK853 System/RBR850/RBS850/RBS850
SXK80 — Orbi Pro AX6000 WiFi 6 Tri-Band WiFi System
There's always a logical answer, if you have all the facts!
Message 2 of 4
atomarchio
Tutor
Yes, there is nothing specific in the manual that refers to what I am looking for.
I am trying to see if there is way to figure out when my kids chromebooks log onto the wifi each morning.
perhaps someone else has a solution and would be willing to share.  thanks.
Message 3 of 4
Guru
Be sure to check out the Orbi AX forum for questions and infornation:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Good Luck.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RAXE500 and RBKE963; Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 366 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
