Orbi WiFi 7 RBE973
Reply
Can't get to 192.168.1.1 from any browser.
rpras
Initiate
This same issue started on my RBR750 - I noticed this today. Can't get to 192.168.1.1 from any browser. The Orbi app does not find the router. Some of the ethernet clients are also not connecting to the router. I don't want to reset the router because I'll lose the current settings. This is very disappointing. I can't even tell which firmware version it is running because I can't get to it!
Message 1 of 4
Accepted Solutions
rpras
Initiate
Re: Can't get to 192.168.1.1 from any browser.
Just to update: last night, this issue was fixed. I did not do anything - must have been an update from Netgear. The firmware version is V4.6.8.2_2.1.9. Of course, the first thing I did was to back up my settings to a file so in case any such event occurs in future, I'll have my settings backed up. That said, I'd like to see a setting in the router to periodically backup the settings to a file.
Thanks Netgear!
Message 3 of 4
All Replies
Guru
Message 2 of 4
rpras
Initiate
Thanks Netgear!
Message 3 of 4
Guru
Glad it's working again. Please mark your thread as solved so others will know. Keep the configuration file on hand. Saves time if a reset is needed.
Enjoy. 📡
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 831 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
