Orbi WiFi 7 RBE973
Reply
Can't turn off Hidden SSID on RBR750
Trevmonk
I have been having problems with connection / slow speeds recently and when I looked on a WiFi analyser app I can see in addition to the normal Orbi SSID there is a duplicate on the same channel called Hidden SSID.  I understand Netgear removed this option sometime ago and there is no way in the Orbilogin control interface now to turn it off. Any ideas?
Message 1 of 2
Guru
Re: Can't turn off Hidden SSID on RBR750
You don't turn it off. They've never been turned off. Its just usually been hidden so it isn't seen by the standard scanners but its always been seen.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 384 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
