Orbi WiFi 7 RBE973
Reply
Can you add a RBS50v2 satelite to a CBR750 syestem?
Eman5150
Follower
I have tried multiple times to see if i can add a RBS50v2 satelite to my CBR750 and had no luck. Anyone else get it to work or does it not? I upgraded to the CBR750 with a satelite and have a bunch of RBS50v2's around from my prior system and was hoping it would work.The same thing is happening with my RBS50Y outdoor as well. I have factory defaulted them multiple times.
Message 1 of 2
Guru
Re: Can you add a RBS50v2 satelite to a CBR750 syestem?
No.
They may work wired though...
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 498 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
