- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Cannot connect to ORBI Router RBR850 and 6 Connected Satellites
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have an ORBI Router RBR850 and 6 Connected Satellites in the house (Ethernet connected).
Is there a limit on the number of Connected Devices (Sonos, MacBooks, etc.) ? We are often kicked out of the wifi or cannot connect with our i-Phones and it is impossible to join any of the 6 satellites or the router.
Yes I restarted the Orbi router (and did a reboot) and wifi and our i-Phones as well, several times, to no avail.
I believe they are all linked via daisy chain (how to check? I think someone told me that I could not use the Orbi app (http://orbilogin.net/start.htm) and needed to set it up differently, but I don't remember).
Should I go for a factory reset of the router and all of the satellites?
Thanks so much,
Francis
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Cannot connect to ORBI Router RBR850 and 6 Connected Satellites
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰
https://kb.netgear.com/31097/How-many-devices-can-my-Orbi-system-support
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/222...
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
