- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- Next »
Cant connect to router but router is still working.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Cant connect to router but router is still working.
Agree. v2 was out on 4-27 when I first posted it for manual download. I and others had it loaded on or around this date. Saw no issues with web page access. I believe the problem started for those that had not updated to it manually on or around 5-5 or 5-6 when NG turned on or started Auto updating users systems and those that had not already updated. Seems like the AU or something behind the scenes got glitched and caused the RBRs web page to be un-accessible from this point. Resets resolved the issue for most. NG seems to have the ability to fix this as well as someone on Reddit posted they contacted NG support and they fixed it on there side with out having to do a factory reset.
- Mark as New
- Bookmark
- Subscribe
- Permalink
This seems to be a problem affecting thousands of users. A factory reset is the only solution working for people that must access the admin section. This is completely unacceptable and Netgear should be honest and open with what they are doing to fix this problem. I have several orbi's across the state and it would be very expensive for me to factory reset each one.
WE NEED A CLEAR STATUS UPDATE FROM NETGEAR.
- Mark as New
- Bookmark
- Subscribe
- Permalink
As of a couple days ago, for me, the issue has gone away. I only noticed an update to the mobile app. Since then, I can control all devices with the mobile app and log into the orbilogin.com site again.
I opted not to do a factory reset as everything continued to technically work and I didn't want to re-configure everything. Hopefully the same solution is rolling out to all users quickly.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any progress on this?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I had this issue once way back. The first thing I did was to reinstall the FW, once I got back into the RBR. But I did a 30/30/30 on all APs; re-updated all APs; Power Cycled all, but left the Sats unplugged while I set up the RBR; once set up I plugged in the Sats and let the system bake for a while. And doing the "Dreaded FW Install" has kept me from having many of the problems that are being posted. The only issues that have popped up are if the FW breaks or changes something.
- « Previous
- Next »
