Orbi WiFi 7 RBE973
Reply
Cheap extension for RBK853?
sundonald
I recently bought RBK853 (RBR850 and 2x RBS850). I'm very satisfied with the system, however I still have a dead spot in the bedroom with almost no signal.
I think it is a bit expensive to buy another RBS850 just for my bedroom. Is there any cheaper solution how I can extend the range? It does not have to be the same speed for this room. I've been looking at the wall plug RBW30, but it seems like it is not supported?
Message 1 of 8
Accepted Solutions
Guru
Re: Cheap extension for RBK853?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
The RBW isn't compatible with Orbi AX. EX are however:
https://community.netgear.com/t5/Orbi-AX/RBK-852-New-Firmware-Version-V3-2-16-6-1-4-4/m-p/1965770/hi...
Message 2 of 8
All Replies
Guru
Message 2 of 8
sundonald
https://ibb.co/GQgM6hJ
Thank you for the help. I did not know about the EX model - that might be a good option..
My home is 170m2 that should be about 1830 Ft.. The big problem is mostly due to the many walls and long hallway to the bedroom. I have attached a drawing of the home and placed the location of the RBR and RBS.
Message 3 of 8
Guru
Seems like the RBS could be placed down farther from the RBR.
Message 4 of 8
sundonald
In straight line it might be under 25ft from RBR to the RBS in the hallway, but there is 2 walls between that makes it tough. I already tried to move the RBS a few meters longer, but then it is unable to make connection. I think buying the EX might be my soloution
Message 5 of 8
Guru
Ok, something to try out...
Message 6 of 8
sundonald
Do you know if all the EX models works with Orbi AX8? And how about EAX extenders? (eax15)
Message 7 of 8
Guru
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1148 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
