Orbi WiFi 7 RBE973
Reply
Costco has them!
tagteam
Virtuoso
Costco has them!
But only a 2-pack! Still the price is good for members comparatively - $549.99
https://www.costco.com/routers-networking.html
Message 1 of 23
tagteam
Virtuoso
Re: Costco has them!
But this is the RBK842 (AX5700) -- 900 + 2400 + 2400Mbps
Message 2 of 23
DBV
Apprentice
Apprentice
Any difference between the Costco ones and the Best Buy ones?  Must be something since it is $100 price difference.  Thanks!
Message 3 of 23
Bandito
Luminary
The Costco system is an RBK842 AC5700 vs. Best Buy's RBK852 AC6000.  From the spec sheet on the Netgear website, it appears that the 842 uses a different, 300 Mbps slower, radio on the 2.4 GHz band.   That must account for the price difference.
Message 4 of 23
farmrt88
Star
It is the RBK842 which is AX5700 rated (900MHZ on 2.4GHZ Band vs 1.2GHZ on the 2.4 Band of the RBK852 AX6000)
However, everything else seems the same. Not sure if AX6000 is that beneficial over AX5700.
https://www.netgear.com/orbi/rbk842.aspx
Message 5 of 23
DBV
Apprentice
Apprentice
So - would you buy the Bestbuy one then since it is faster or not worth the extra $100. Guess Costco has better return policy.
Message 6 of 23
Bandito
Luminary
I would think that you'd probably not notice the difference in speeds unless you have a large number of 2.4 GHz 802.11n devices on your network.  Even so, the $100 price difference seems a little steep for the relatively small speed difference.
Message 7 of 23
tagteam
Virtuoso
Yeah, I wouldn't despite being a Costco member and having bought my RBK53 system there over 2 years ago.
The downside, for me personally, is the fact that the Costco system only has 1 satellite. As a result, I'd just pay the extra $100 to get the extra speed.
In my experience with routers, and other electronics, if the hardware is going to go bad, it's going to happen fairly soon after being deployed. If I were really paranoid, I'd just buy the extended warranty but, at this point, I'm sticking with my RBK53 setup.
Message 8 of 23
DBV
Apprentice
Apprentice
I noticed the BestBuy has the Linksys MX10 on sale for $100 off.  Maybe Orbi will follow suit.  They both sound competitive on WiFi 6 based on very limited reviews.
Message 9 of 23
tagteam
Virtuoso
Competitive and Linksys offers a single unit (MX5) for those who might need more than the MX10's 2-Pack. I mean, an MX10 + an MX5 would cost $1,000 but at least Linksys is offering that configuration. Netgear needs to do the same and, actually, both companies need to offer a 3-Pack.
Message 10 of 23
DBV
Apprentice
Apprentice
Agree with you.  I think both companies should offer a 3 pack for the price they are charging.  Orbi needs to match Linksys price now, as I don't think there is any significant differences between them.
Message 11 of 23
Guru
NG did the same thing with there XR gaming routers. The XR500 was public while the XR450 was sold at Costco only. Same HW and FW everything accept for the 2.4Ghz radio which was slower than the XR500 is all. The XR450 was $100 cheaper at Costco. How I got my XR450.
Message 12 of 23
tagteam
Virtuoso
Yep, it's kind of strange -- some are the same and some are slightly different, such as the units you mentioned and something like the Nighthawk AX8 AX6000, which is the AX8 AX5700 at Costco. Then, the original Orbi units appear to be the same at Costco as those sold everywhere else. Go figure.
Message 13 of 23
Guru
NG is milking the market. Smiley Wink
Message 14 of 23
DBV
Apprentice
Apprentice
I guess so.  Just found out I can get the Linksys MX10 2 pack for $419 through work benefit.  Guess will try them.  Feel bad though, as I have liked all my Orbi products so far....  🙂
Message 15 of 23
tagteam
Virtuoso
Yeah -- LOL! But it's confounding to me because. although I realize the component might be cheaper, creating two separate manufacturing lines would create additional expenses.
Message 16 of 23
Guru
Not really as they are using the same HW and case design. There just making changes to the 2.4Ghz wifi aspect is all in FW. Same code base as the 850 series with minor changes. Majority of the testing with beta has been done on the 850 so bugs would be the same for the 840 series. Easy way to get additional market value. Same happened with a number of NG routers they did between public and Costco. R8000P and R7960P was based off the R8000.
Message 17 of 23
tagteam
Virtuoso
Huh! So, if one had access to the 850 FW the Costco 840 could be transformed into the 850?
Message 18 of 23
Guru
HW/FW restricts this. Not sure why you would want to do that anyways, if the only difference is the 2.4Ghz wifi then something one wouldn't need to change.
Message 19 of 23
tagteam
Virtuoso
@FURRYe38 wrote:
HW/FW restricts this....
OK, but that's what I don't understand. If the HW is not IDENTICAL, then there has to be more than one line.
Message 20 of 23
Guru
2.4Ghz would only be the difference....wheather one could force 850 series to 840 series and try to make it work. Don't know. Otherwise the HW is the same as so would be the FW. However NG I presume prevents any 840 series FW from loading on 850 series systems with in the  FW.
I I know that Linksys had problems with there WRTx32 router FW being loaded on the WRT1900ACS. Or was that the ACM. Someone found out that the x32 FW as compatible on the ACS back then. I think Linksys closed that gap.
At any rate if the only thing that differs is the 2.4Ghz HW and speeds is a bit lower, I wouldn't see a need to modify the system to make ti work like the 850 system. If your getting the same 5Ghz and 5Ghz wireless backhaul speeds, seems like too much hassle to make a 840 series like a 850. I thought about the same for my XR450, however nothing I can do for it. Just limited by HW and FW with the 2.4Ghz radio. Otherwise, it's a XR500 with a slower rated 2.4Ghz radio is all. Works the same though. Good gaming router. Currently running it front of my RBK852 in AP mode.
Message 21 of 23
tagteam
Virtuoso
Right! So, I suppose it's just the FW loaded initially that cannot be circumvented (overwritten) with another version - makes sense anyway because as you stated there isn't really a distinct advantage. Just kind of weird that they would even bother with it but.......marketing!!
Message 22 of 23
Guru
Exactly.
@tagteam wrote:
marketing!!
Message 23 of 23
Top Contributors
Discussion stats
  • 22 replies
  • 7283 views
  • 0 kudos
  • 5 in conversation
Announcements
Orbi 770 Series
