Reply
DNS Issue with RBK752
hawkinsb
Just got a new RBK752 system. I use CleanBrowsing DNSs to filter for my family:
IPv4 Address185.228.168.168 and 185.228.169.168
IPv6 address2a0d:2a00:1:: and 2a0d:2a00:2::
What I'm seeing is that when just using IPv4, I get random DNS errors that immediately resolve themselves while web browsing. I noticed in nslookup that I see a 2 second timeout followed by a successful resolution. All using Windows 10.
I then kicked on IPv6 in the router and added the IPv6 CleanBrowsing DNS entries there also, and the problem seems to go away. I've tried using other filtering DNS systems (OpenDNS, for example), and I can't reproduce the issue there. Never had a problem with CleanBrowsing on my old R7800.
Thoughts? Thanks!
Message 1 of 6
Guru
Re: DNS Issue with RBK752
Do you still get DNS errors if you use default auto detected DNS?
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Gateway Mode | Wifi Routerand RBK853 | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50v2, XR450/500/700, EX7500/EX7700
Message 2 of 6
hawkinsb
Netgear is firmware version V3.2.10.10_1.2.12.
Cable modem is an Arris SB8200. I do not get errors when using the default ISP (Comcast) DNS that is auto detected
Message 3 of 6
Guru
Now what happens if you try Quad 1s and Quad 9s for DNS...?
Message 4 of 6
hawkinsb
Every other DNS I've tried has been fine. Just the CleanBrowsing DNSs seem to cause the issue...
Message 5 of 6
Guru
Something to contact NG support. Seems like this one particular DNS service isn't working with Orbi. They will have to take a look at this.
https://www.netgear.com/support/#
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 500 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
