Orbi WiFi 7 RBE973
Reply
Does the orbi wifi 6 work with the rbs20 or rbs50 units all connected via ethernet wire?
Rikerrock
Tutor
Will these older addons work with the new orbi 6 mesh system connected via hard wire?  I saw a mesh system from costco and was considering getting it.  Also, are people finding better speed etc with the orbi 6 vs the older mesh?
thanks
Message 1 of 2
Guru
Re: Does the orbi wifi 6 work with the rbs20 or rbs50 units all connected via ethernet wire?
Yes you can ethernet connect Orbi AC RBS to Orbi AX though you may need incorrect status on the RBRs Ui.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 404 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
