Orbi WiFi 7 RBE973
Reply
Double net and ip addresses allocation
devdeep
Guide
I am confused by who allocates isp addresses. Connection is: ONT--> isp router--> my router ("X")
Isp router does not allow DHCP switch off and is necessary to connect my phone to it.
1. If I let the isp router handle ip addressing, to avoid resetting all devices on my current router (X), can I give the isp router the same SSID as X? X has ethernet wired switches - will the same name cause issues?
2. If I turn off WiFi in the isp router, presumably X will provide the ip addresses (as it is now). I can ignore other ethernet ports in the isp router so only address given by it is the X ip address.
3. In 2 above, any other double net issues I need to consider?
Message 1 of 4
Guru
Re: Double net and ip addresses allocation
1. If I let the isp router handle ip addressing, to avoid resetting all devices on my current router (X), can I give the isp router the same SSID as X? No. X has ethernet wired switches - will the same name cause issues? Yes.
2. If I turn off WiFi in the isp router, presumably X will provide the ip addresses (as it is now). I can ignore other ethernet ports in the isp router so only address given by it is the X ip address. Yes.
3. In 2 above, any other double net issues I need to consider? Use the ISP routers DMZ to help avoid double NAT issues or configure AP mode on the X router leaving the ISP router to handle all router duties.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RBKE963 and RBE973 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
Message 2 of 4
devdeep
Guide
@FURRYe38
Thanks a lot. Let me digest this (being a newbie!) and come back.
Message 3 of 4
Guru
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 318 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
