Orbi WiFi 7 RBE973
Reply
First time instalation
Faarr
Initiate
Just bought the rbk853 at first time installation, i had a firmware update. I connected my Orbi router with my modem. After that the router worked but i cant connect the 2 satellites. I resetted the router and satellites yet they wont connect. Can someone help me out? I thought this would be plug and play
Im thinking of bringing it back because it doesnt work
Message 1 of 4
Guru
Re: First time instalation
try hardwiring the satellites into the router and trying to sync them. make sure they're on the same firmware versions.
Message 2 of 4
Faarr
Initiate
They are hardwired, thought my wall outlet. How do i know if they have the same firmware?
Message 3 of 4
Guru
Take the satellites too where the router is, factory reset the satellites, and use a known good 6ft cable and hardwire them into the router. Then give it a bit for everything to boot up and log in through the GUI (browser) and see if they connected. From the GUI you can check the firmware.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 606 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
