Orbi WiFi 7 RBE973
Reply
Guest network on Orbi mesh node
bychin
Follower
Am I able to set up a guest network on an Orbi WiFi 6 AX6000 (RBK852) mesh node? My current mesh system only allows a guest network on the router and not the node. I would like to set up the guest network on the node since it will be in a room closer to where guests would stay.
Message 1 of 2
Accepted Solutions
Guru
Re: Guest network on Orbi mesh node
When Guest Network is enabled, it's enabled on all Orbi RBR and RBS units.
Message 2 of 2
All Replies
Guru
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 601 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
