- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Headaches from Orbi WiFi 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sixty days ago I purchased an Orbi WiFi 6. It worked great, and produced the best Internet speeds we have ever had. My wife and I were quite pleased. We began having headaches and brain fog, which went on for about three weeks. We even tested for Covid in trying to discover what were causing our severe headaches. We finally realized the headaches and brain fog started shortly after installing the Orbi router. I unplugged the Orbi and connected our old Netgear Nighthawk. In a day our headaches were gone. In a few days our brain fog was lifting. After about two weeks I connect the Orbi again, and our headaches returned. We are again using the old Nighthawk. I called Netgear asking about returning this $360 router, and was told I could not because it was over 30 days since I purchased the router. The product made us ill and we should be able to return it within this short period of using it. I do not know if other people have experienced this problem, but it is important to have this discussion. There seems to be a health issue that should be researched.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Headaches from Orbi WiFi 6
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Orbi WiFi 6 (AX) and WiFi 6E (AXE) - NETGEAR Communities
Maybe someone there has had similar experiences.
- Mark as New
- Bookmark
- Subscribe
- Permalink
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
