Orbi WiFi 7 RBE973
Reply
I do not login to my router too often...
jk2017
I do not login to my router too often, but today I needed to check something and hit this issue.
Is it correct that if I wait 'some time' it will get updated and (hopefully) fixed?.
I don't really want to do factory reset if I can avoid it
Message 1 of 6
Accepted Solutions
Guru
Re: I do not login to my router too often...
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Message 6 of 6
All Replies
Guru
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/NETGEAR-is-rolling-out-a-fix-for-an-...
Either wait, contact NG support or factory reset if you need more immediate access.
Message 2 of 6
jk2017
Now 3 weeks later I'm still not able to log in to my RBR750.
My WiFi is working, except for the non-access to the setting, so I'm a little weary of factory resetting the router.
But I guess that is my only option now. Download Firmware-Version-v4-6-8-2, factory reset router and satellites, then upgrade.
Message 3 of 6
Guru
What I would do. BE SURE YOU UPDATE THE RBS FIRST, then the RBR lastly.
Message 4 of 6
jk2017
I did a factory reset, upgraded to v4.6.8.2 on both router and satellites. And all is working again - whew
Message 5 of 6
Guru
Enjoy. 📡
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 970 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
