Orbi WiFi 7 RBE973
Reply
IS THE RBKE963 COMPATIBLE WITH RBS 850 AND 750 SATELLITES?
tabishop
I have an RBR850 with several RBS850 and RBS750 Satellites.  The coverage is good not great and some of the satellites are hard wired in outbuildings.  I would upgrade to the new RBKE953 if I could still use my legacy Wifi6 satellites. Does anyoneknow if the RBRE950 is backwards compatible with Wifi6 mesh satellites?
Message 1 of 6
Accepted Solutions
Guru
Re: IS THE RBKE963 COMPATIBLE WITH RBS 850 AND 750 SATELLITES?
Orib 7 and 8 series RBS will not connect to the Orbi 9 series system.
Message 4 of 6
All Replies
Guru
They are not compatible.
Message 2 of 6
tabishop
Appreciate the quick response.  Are you saying that the Wifi6E signal won't extend to non-wifi6e satellites or the satellites won't talk to the wifi6e router even for the 2.4ghz signal used by cameras etc.?
Message 3 of 6
Guru
Message 4 of 6
tabishop
Got it.  Thanks!  Too bad Netgear makes it so expensive to upgrade.  My next system will be an Eero, even though it's not as good, it will be more affordable to maintain.
Message 5 of 6
Guru
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 2007 views
  • 3 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
