- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Internet dropping on Orbi V4.6.3.16_2.0.51
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I have an Orbi Router with Satellites.
In the past sometimes internet dropped for a minute or two, it quickly resolved itself. I thought it was related to my ISP.
But today internet connection is dropping continuesly. If I reboot my Router and then it works again for a while, so it's related to the router, not my ISP.
Router info:
Hardware Version | RBR750 |
Firmware Version | V4.6.3.16_2.0.51 |
GUI Language Version | V3.0.1.2_2.1.30.3 |
Operation Mode | Router |
LAN Port | |
MAC Address | 38:94:ED:48:C7:BF |
IP Address | 192.168.1.1 |
DHCP | On |
Router firmware is on V4.6.3.16_2.0.51.
Traffic meter is disabled.
Any help would be greatly appreciated as this is causing quite some stress when working from home..
Thanks, Ken
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Internet dropping on Orbi V4.6.3.16_2.0.51
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode | Wifi Router XR500 and RBK863 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have a look here:
New RBR750 / RBS750 Firmware Version 4.6.3.16 Rele... - NETGEAR Communities
Most likely you're not alone.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you, it seems I'm f**cked then.
For me it always happens during an MS Teams call now, very frustrating.
It seems there is not much to do other than a factory reset...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
I would not mark your post as solved until we identify the real problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @FURRYe38 , I did not know this topic was marked as solved. I did not do this but maybe I clicked wrong somewhere.
Anyway. The problem is not solved. I've been working from the office mostly the last 2 weeks so problem was limited to my kids getting annoyed when playing Brawl Stars :-).
Anyway, over the weekend I have been struggling with this problem again myself - A LOT :-).
And then all of a sudden I seen an update available: V4.6.5.14_2.0.54
I thought "yes!" but the problem is not gone and even seems to be getting worse.
I also restarted both the router and the modem after the update.
Anyways, here is the model number of my modem. Provider is Telenet in Belgium.
-> 24*8 DOC 3 WIRELESS(DOCSIS)
My modem also contains a wireless network which is disabled. I'm going to enable that to "proove" that the problem is with Orbi: if Orbi says "no internet" and the wireless network on my modem still works, I hope this helps to get my money back if this does not get resolved.
I'm already pretty sure since a reboot of the Orbi resolves the problem.
Any other tips would be greatly appreciated!
- Mark as New
- Bookmark
- Subscribe
- Permalink
If the modem has wifi built in, then this means the modem will have a router built in as well. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
I would try option#2 first, then Option #3...
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 , thank you.
Your response helped!
But not the way you think. Just got of the phone with my ISP to check about the bridging, and appearanty my Modem is randomly restarting.
They are sending someone over to investigate the problem and probably replace the router.
Thank you anyway for your help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well thats good too that they found the main problem. Hopefully that will get things working better for you.
I would have them bridge the modem if it supports it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
