Orbi WiFi 7 RBE973
Reply
Is AC 1750 - C6300 Modem router compatible with Orbi WiFi 6 System (RBK752) AX4200?
vorona_fox
Follower
Model: C6300|AC1750 Cable Modem Router Docsis 3.0
Message 1 of 2
Guru
Re: Is AC 1750 - C6300 Modem router compatible with Orbi WiFi 6 System (RBK752) AX4200?
Yes. It's recommended that you bridge or put the modem into modem only mode if you connect any external router to the modem. The modem already has a built in router and wifi system. These needs to be disabled prior to connecting a external wifi router.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 689 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
