Orbi WiFi 7 RBE973
Reply
Is ORBI RBK752 region locked?
Francisco1202
Follower
Hi,
Im considering buying the netgear orbi RBK752 in the US, but i want tou use it in Peru (south america), and i wanted to know if there is some sort of region lock for the product, or if it is only going to work in the US.
Thanks
Message 1 of 2
Guru
Re: Is ORBI RBK752 region locked?
When you log into the RBRs web page, do you see a drop down under the right upper side under the FW version display? Select this AUTO and you should see a drop down menu. Can you select something close to your region here?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 437 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
