bryn41's avatar
bryn41
Follower
Mar 23, 2023
Is a wired satellite able to give Wi-Fi devices signal?
This may be a dumb question but I have an Orbi system - AXE10000 - with two satellites. One is wired and one is connected via wi-fi. When I check in the app, the only device that shows as being connected to the wired satellite is an Apple TV that is hardwired into it. All other devices seem to be connecting to the wi-fi- connected satellite despite it being significantly farther away. My question is: does hardwiring an Orbi satellite prevents its Wi-Fi functionality in some way?
(It is worth note that the wired satellite is located behind a television. Is that causing sufficient interference to cause what I am seeing?)
Thank you for any input and guidance.
  • CrimpOn's avatar
    CrimpOn
    Absolutely not.  Satellites broadcast WiFi no matter how they are connected to the router.
    Yes.  Metal interferes with WiFi signals.
  • FURRYe38's avatar
    How is the RBS connected to the RBR?
    Directly in back of the RBR or is there a LAN switch in between?
    Are you using the 2.5Gb port on the RBS and RBR or the 1Gb ports?
    What CAT# lan cable are you using? CAT6A STP is recommended for 2.5Gb ports. CAT6 UTP for 1Gb ports.
    https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System 📡
    What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
    Placement of the RBS behind a TV could cause some problems. 3-6 feet distance away from other electronics is recommended.
