Orbi WiFi 7 RBE973
Is it possible to link a sewing machine with wifi to my Orbi network?
Bevchristof
Hi
I have the above Orbi system.  Is it possible to add a sewing machine with wifi to my Orbi devices?  At the moment I can only transfer designs to my machine by logging out of Orbi, downloading the design and then logging back into Orbi.  It would be good if I could add my machine.
Can this be done manually?
Thank you
Message 1 of 11
Accepted Solutions
Guru
Re: Is it possible to link a sewing machine with wifi to my Orbi network?
Never in a day would I have thought that a sewing machine would get technical and get WiFi abilities. My grandmother would be amazed if she was still around. She had a peddle machine back in the day. 😉
Message 11 of 11
All Replies
CrimpOn
Guru
The place to start is with the User Guide to the sewing machine.
Message 2 of 11
Bevchristof
Hi, Thank you,  There is no mention of this in the user manual.
Message 3 of 11
CrimpOn
Guru
The specific model of sewing machine?
(or, a link to an on-line version of the User Manual)
Message 4 of 11
Bevchristof
Hi
It is a Janome S9. I can join it to our wifi but Orbi does not recognise it so I have to log out of Orbi every time I want to send a design to the sewing machine.
Thank you for your help.
https://www.janome.com/siteassets/support/manuals/embroidery-models/inst-book-sks9.pdf
Message 5 of 11
CrimpOn
Guru
Thanks for the information.  This video seems pretty self-explanatory:
https://www.youtube.com/watch?v=W2VVQuaM2ts
The key appears to be running their Embroidery application on the computer/tablet and selecting the sewing machine from the list of devices.
Once the machine has been connected to the router, the Attached Devices screen, or Device Manager on the Orbi 'app' should display the same information that the machine does in terms of IP address.
Where does the process break down?
Message 6 of 11
Bevchristof
Hi
Thank you.  I have no problem with connecting the machine and iPad to our network the problem is that,  even though both devices are connected to the same wifi when I go to transfer the design to my machine I get a communication error saying connection failed. My machine does not show up on the list of connected devices on Orbi.  If I log out of Orbi I can do to the transfer.  To me it appears that Orbi is not recognising my sewing machine even though it is connected to our network.  It is no biggie to log out when I need to do a transfer but it would be easier if I didn’t have to do that.  Thanks again for your help.
Message 7 of 11
CrimpOn
Guru
Not right at all!  What resources are available to troubleshoot the connection?
(computer/laptop/tablet connected to the network that can run a network application?)
For example, my first step would be to use the Internet Control Messaging Protocol (ICMP - often called 'ping'), either by opening a command window and typing in the command ping 192.168.1.x, putting in the IP address reported by the sewing machine.  There are are apps on my phones and tablets that offer the same function.
Or, I would use a "network scanning application" to list out all of the devices connected to the LAN IP subnet.  Depending on the model of Orbi, the Attached Devices display may show devices "out of sequence".
When the app shows connection failed, did the sewing machine appear as an option in the embroidery app?  (the machine not appearing at all would certainly indicate that it is not on the network.  Showing as available and then connecting might be something else.)
We so seldom have a really fun topic on the forum. Please do not give up yet.
Message 8 of 11
Bevchristof
Hi, I really appreciate your comments and suggestions.  I will try and ping the machine when I get home.
When I get connection failed the machine does not show on the app.  Once again if I log out of Orbi it does appear.  Anyway I will try what you and suggested and report back.
Message 9 of 11
Bevchristof
Hi.  I pinged the machine and then ran a scan and the machine is now showing up.  I don’t know what I did but I can now transfer designs using my ipad.  I still have an issue with my macbook but I am not worried about that as I mostly use my ipad.  Thank you so much for all your help.
Message 10 of 11
Guru
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 1140 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
