- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Looking for recommendation - Mesh network
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm just looking for a simple mesh solution.
I need at least one device that is outside however. All the orbi packages etc are all inside devices.
I'm not a networking guy - just looking to plug in some things that will work and I get a simple ubiquotous network inside/olutside the home which allows me to conenct and stream to our indoor AVR from the pool , etc..
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Looking for recommendation - Mesh network
30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Do you have support or AX wifi?
https://community.netgear.com/t5/Orbi/Find-Your-Orbi-With-the-NEW-Orbi-Product-Selector/m-p/1907267/...
https://www.netgear.com/orbi/default.aspx
https://www.netgear.com/orbi/wifi-systems.aspx
https://kb.netgear.com/000038220/What-are-the-hardware-specifications-of-the-available-Orbi-WiFi-Sys...
Orbi AX doesn't have a outdoor satellite at this time. Orbi AC system does, RBS50Y which works outdoors.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Whendingo wrote:I'm just looking for a simple mesh solution.
If you have an inside area near the pool, you would not need an outdoor device. Depending on what system you decide on, the router or satellite will have great WIFI coverage. I do not have any outside units and my pool gets great WIFI coverage from a mesh satellite 30 feet away.
Choosing your system is going to depend on the size and layout of your home. And when looking, don't be fooled by the Up To WIFI sq footage coverage. A lot of variables in the home will diminish those figures.
