- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Losing connections between RBR750 router and RBS750 satellites
- Mark as New
- Bookmark
- Subscribe
- Permalink
I keep losing connection between my router and satellites, especially one in my playroom. What is frustrating about it is that my older Orbi system did not do this. I recently upgraded to the RBR750 and RBS750 sats to increase speed and capacity. I am wondering if there is/are settings I need to adjust to make the connections more reliable. Any insight would be greatly appreciated.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Losing connections between RBR750 router and RBS750 satellites
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
https://community.netgear.com/t5/Orbi-AX/RBK753S-update-Rock-solid-in-terms-of-speed-and-stability-s...
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-...
https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-port-forwarding-doesn-t-work/td-p/198...
