Duffer10
Sep 14, 2024Follower
Mesh and Spectrum
I have a spectrum modem/router combination, and I want to go to the orbi mesh to increase my WiFi coverage. I am not a total geek, but I think I can do this. I have heard that the Spectrum combo might be a problem, and, honestly, I’d prefer something plug and play. I currently have a coax cable from the street to the unit. Can I just connect the node into the current Spectrum unit and somehow disable the router portion of the spectrum, and use the same settings? I’m not sure how many nodes I will need, what is an average length of node placement to maintain speeds. Thank you for your help.
1 Reply
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...What is the model# of the Orbi system you have?
How many RBS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰Too Much Wifi: https://youtu.be/UR0viMLISz4
