× You're Invited! Orbi RBK763 Beta Firmware Testers Needed. To participate in testing this trial firmware, please click HERE.
Reply
My Orbi RBK753S JUST CUTS OUT AND " NO INTERNET CONNECTION"
BlueSurf
I'm getting so frustrated several times each day I fing I cannot get web pages.  My phone says " NO INTERNET CONNECTION".  I use my cell on LTE and I'm back on.  switch to wifi and NO Service from my Orbi.  Does anyone know whats going on?  I feel sorry I  made this purchase.  I already dissconnected Armor.  What a useless program.  It locked me ourt of so many needed sites.  No service is worse!  Any ne have this issue too?
Message 1 of 6
Guru
Re: My Orbi RBK753S JUST CUTS OUT AND " NO INTERNET CONNECTION"
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode  | Wifi Router RBK963 and RBK853 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 6
BlueSurf
Firmware Version
V3.2.16.6_1.4.4
My modem is: ARRIS SURFboard SB6190 DOCSIS 3.0 Cable Modem
My home is 2400 sq. feet
My Orbi modem is in the center of the house, a Ranch all on one level.  The 2 satelittes are 22 feet apart with the modem in the center of the straight line.
Xfinity is my service 100Mbs
7 wifi neighbors
2.4 channel: I switched from Auto to #1
5.0 GHZ channel: I am on channel 48
I gave up my Google mesh and never had drops in my service until Obri my was set up.
Thanks for your assistance.
Message 3 of 6
Guru
"The 2 satelittes are 22 feet apart with the modem in the center of the straight line." This would be a bit too close.
FYI, your model modem has a known problem with in itself and is not recommended for use.
http://www.badmodems.com
Message 4 of 6
BlueSurf
Thanks for your assistance.  I spoke to some neighbors this afternoon and it seems they too have having simular issues.  It has to be Xfinity having issues with the high heat and high usage while many people are at home.
Message 5 of 6
Guru
Well there was this yesterday morning. Not sure if XF has any ties to what happened.
https://www.zdnet.com/article/centurylink-outage-led-to-a-3-5-drop-in-global-web-traffic/
I did see two IoT services that I have that I could not connect too. Later on they were accessible.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 744 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
