- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
MyQ 2.4G Garage to Orbi RBR750 (non-technical)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Like many folks I was having difficulty getting the MyQ garage door opener set up after upgrading to Orbi AX4200. I understood that the problem was my phone was connecting via 5G to the network instead of 2.4G due to the Mesh. I was not comfortable updating my router settings from a command line to seperate the 2.4G and 5G SSIDs. I was very frustrated, when I remembered that 2.4G had much longer range the 5G. So, I unplugged my satellites and covered my RBR750 with two metal stock pots. This "artifical distance" due to interference degraded the signal in my garage to the point that I was out of 5G range and I connected via 2.4G. Once on 2.4G, I was easily able to change the MyQ wifi settings in the phone app. Voila. Problem solved.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: MyQ 2.4G Garage to Orbi RBR750 (non-technical)
Also try turning down the power output of the RBRs wifi radios from 100% to 25% Under Advanced Tab/Advanced Settings/Wireless Settings as well to help with the distance vs connection with the mobile device.
Enjoy.
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode | Wifi Router RAXE500 and RBKE963; Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
• Yes! WiFi 7 is backwards compatible with other Wifi Devices? Learn more
