- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
NETGEAR Orbi Mesh WiFi 6 RBK752, wireless region set to "China" but system bought in Italy
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
I purchased the NETGEAR Orbi Mesh WiFi 6 RBK752 in Italy on Amazon but the region of the Wi-Fi is set to China without the ability to change it from Advanced -> Advanced -> Wireless Settings because the menu is grayed out.
Is it possible to change it or should I return it? Is it possible to do something? I'm afraid wireless performance is limited by this setting.
Greetings,
Paolo
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: NETGEAR Orbi Mesh WiFi 6 RBK752, wireless region set to "China" but system bought in I
Try a factory reset on the RBR and setup from scratch...
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode | Wifi Router RBK963 and RBK853 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
thanks for replying me.
SW version is V4.6.5.14_2.0.54
How should I perform factory reset?
Best regards,
Paolo
- Mark as New
- Bookmark
- Subscribe
- Permalink
Some regions lock their region settings.
If yours is locked to the wrong region, you'll probably need/want to exchange it.
You used to be able to telnet in and change it with the burnsku command but telnet was locked out as well as I think it voids a warranty.
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Press the reset button in back of the router for 15 seconds then release. Connect 1 wired PC to the back of the RBR and walk thru the setup wizard in a web browser pointed at 192.168.1.1, see if the language drop down menu items seen on the upper right hand corner can be changed to something else. If not, as suggested, send it back and get another for your region.
@Paolo_Coppi wrote:
Hello,
Best regards,
Paolo
- Mark as New
- Bookmark
- Subscribe
- Permalink
