senadaruc's avatar
senadaruc
Netgear Orbi RBKE963B and VLAN on WAN connection ?
Hi,
I have a fiber optic internet connection where I need to define a VLAN for the internet separating the IPTV and VOIP.
Is this possible with Netgear Orbi RBKE963B ?
    • senadaruc's avatar
      senadaruc
      Is this going to work with my Fiber Optic media converter, where I need to have a VLAN on WAN/Internet port?
      • FURRYe38's avatar
        You'll need to ask your ISP about this to see what is required from them for any VLAN configurations. They will know.
        IF the RBR is connected to the media converter then this would be the place the RBR needs to be connected. Check with the ISP though.
